Hello Jyuma, I relisted to be more specific, the info you gave me isn't really what I'm looking for The manual listed is not available if you go to purchase. The pdf you sent me is a much newer machine then mine, the hydraulics are totally different. I do appreciate your help. I would assume the seals and orings are probably available from Cisco or other parts houses. PSI believe you already asked this question... do you need more help? http://www.skidsteerforum.com/DesktopDefault.aspx?tabid=54&frmView=ShowPost&PostID=47082
Did you ever find a manual? I believe my Thomas is the same vintage and would be simular. Could you share your source for the maual if yoiu did?lHello Jyuma, I relisted to be more specific, the info you gave me isn't really what I'm looking for The manual listed is not available if you go to purchase. The pdf you sent me is a much newer machine then mine, the hydraulics are totally different. I do appreciate your help. I would assume the seals and orings are probably available from Cisco or other parts houses. PSnot sure if you know of Cisco sub of Ackland Grainger, they have a great store for hydraulics in Mississauga)
