2023 T86 getting plugged filter error codes only 70 hours on machine
RIGHT maybe filter clean but the sensoir is sensinging dirt or dust
I believe sensor is measuring air pressure difference. Higher difference between surrounding air vs. intake air; indicates a restriction. Whether restriction is at air intake, collapsed air intake duct, or dirty air filterl sensor doesn't know.
Did you have any luck with a fix? I've been dealing with this for 6 months and ready to return the machine.
Buy a Donaldson pre cleaner and weld a flat bracket with tabs on it and then you can have the pre cleaner and take it off to be able to lift the cab.. what I did
