2012 333D wont shut off
lightning14
Tried turning it off today and I turn key and nothing. Can take key out and still nothing. Was able to shut it off by blocking intake but lights on switches are still on so had to disconnect battery. It will start right back up if I turn key
Bad fuel shut-off solenoid would not cause lights to stay on with switch off unless the fuel solenoid also controls electricity.
I'd start with a voltmeter on the ignition switch, which should be breaking 12 volts to the rest of the electrical system when turned off.
Trace the wires (circuits) from there. Find the source of the 12 volts and you'll find your problem. (Assuming a 12-volt system).
I know this is old but did you figure out your problem. I have same machine with the same problem
