2006 bobcat 5600 wont move
FarnorthMN
Hey guys thanks for having me. I searched this topic, but couldn't find anything like what I am experiencing. I have 5600 that I was snowblowing with and just stopped moving
Along with no hyd fucntion or steering with no codes showing up. Move the armrest and park light does go off and when you try moving the FNR while in park it still beeps at me. Hyd. oil is in the sight glass and when I start the machine it does move the hyd. Oil level down "sucks down". I will start checking speed sensors and wire harness. Has anyone run into this same problem?
PIN A00311370
1900 Hrs
Thanks everyone!
I think the biggest clue is that the hydraulic oil level drops when you start it. That tells me your pump is trying to work.
Maybe you should check the coupler between the engine and the main hydraulic pump. It's a common part to break on these machines, especially with that many hours. It could have just stripped out.
you were right. pulled the drive belt cover off and found the drive belt broke. also checked the drive belt tensioner and found the spring broke that as well. Appreciate the input!
