2003 85 xt
marioc
i own a 2003 85 xt that i bought with 300 hrs. my problem is that when you go to move the hand controls to raise the louder frame that 1 st 1/4 inch you move the hand controls out the loader frame goes down instead of going up once you get about 1/2 inch past 0 the frame goes up. the bucket does the same thing . but if you hit the aux button or the aux foot the frame goes up like it should. i took the loader control out and changed all the o rings and not did find anything visually wrong with it . put it back in and the sane thing. ive played with the main relief valve on the loader control .same thing . my machine have a 2spool loader control no extras like bucket level no pilot controls just levers . i am almost at the point were im going to bring it to the dealer . can anyone help me thanks mario
It sounds like a problem with the load checks.
Each spool in the valve should have one.
No idea how they look on the case valve, look at the hydraulic valve in the manual there should be one port for each spool marked "load check"
I had the loader control apart and the load checks look ok.I was thinking main relief valve. Thanks
