2001 Bobcat 773G timing gear case cover leak
dcdturbo
I have a 2001 bobcat 773G with kubota V2203TE , just over 2400 hours it started leaking oil from timing cover behind oil filter above oil pan, it appears to be the gasket. Can I just remove the timing cover and replace the gasket or is it a major operation.
It's not a hard job, but there will be a gasket, Orings for the oil galleries, you should replace the crank seal too, you don't want to do the job again if it was to leak as well.
