2000 NH skid steer ---Rebuilt pump --steady increase in RPM
oldman716
i rebuilt the pump-delphi 200 --[ 2000] -the head rotor drive broke --replaced with a new head - had timing problems --finally set to 10 deg. BTDC ---AT TDC AND 10 DEG --- after start-- steady increase in RPM --slight change with throttle --seems to run wide open ----no after run when shut off --weights are working --
I finally got to look at the manual I have. Thought it would give me the timing info but it only has the LS190 (29 BTDC) info, but that is a different engine. The LS180 has the 332T New Holland (formerly Ford) 3 cylinder engine in it. It was also used in several tractor models. You could call Messicks (google them). They are a large New Holland dealer with a helpful service department. They could certainly confirm the timing info for you. I don't know how in depth on the pump internals they would get. Another idea is to post on Machinery Talk (part of AgTalk). I've seen more injection pump discussion in there. Good luck. Sorry I couldn't help more.
I have the service manual for the LS180 that shows 332T/JF as the engine model.
Does this help?
