Bobcat is equipped with the BICS and getting code 1 from the valve light indicating that the valve output circuit is open. ( arms and tilt won't work) I have replaced the control valve solenoid, checked the wire for continuity and to see it is not shorted to ground. (all good) still get same flashing code and arms won't work. I powered the solenoid directly and could hear a soft click. I replaced the BICS light indicator panel with new one and same problem exists. Earlier on with my machine this problem of the arms stopping their normal function has happened and usually a shut off and restart solved the problem. All other functions operate normally. I checked the traction lock circiut ,wiring and solenoid and all appear to work properly. Any ideas where to look next. Could it be the BICS computer if that is what it is called and it is located on the back left side of the cab facing the engine. (the tilt has a self leveling feature if that might be a consideration) Thanks Rudy
