1988-743 bobcat how do you remove engine
Disconnect the battery
Drain the coolant
Remove the exhaust pipe and radiator hoses
Turn off fuel and disconnect lines
Disconnect wires from starter
Unbolt relay block from frame
Disconnect engine wiring harness from cab harness
Disconnect throttle linkage and air cleaner hose
Remove engine mounting bolts
Slide engine out onto something that will support its weight
Installation is reverse of above but will require someone to help to align u-joint onto spline while you push the engine back in.
Drain the coolant
Just pulled mine by myself except for a bit used 97 lb wife to push a lever to help over the lip piece of cake put new u joints in !!!!!!!!
Do not remember the relay block on the frame
A 743 is quite simple to remove and replace. Just make sure you have a helper on hand to line the yoke between the engine and pump up when putting it back in. And keep your fingers away from the hole of the yoke when installing it, you don't want a few hundred kg engine pushing on one side, pump the other and finger in the middle.....
01325b9abd5d833c2bbdfc1e3a8e3447ca7f3f3f6e 014f309b0f94ee0d06a205b46dffe0679d53f519cd 012fdac3db7189683f78ee36f8c1badb1c96490aa2 01cdd985832015db204fc28961cc96e69e81457fe8 yes very simple 4 bolts hold it down on frame 2 fuel lines on mine and the wire harness and 2 ground wires but very easy you will need help guiding the universal back on to the pump shaft
01325b9abd5d833c2bbdfc1e3a8e3447ca7f3f3f6e 014f309b0f94ee0d06a205b46dffe0679d53f519cd 012fdac3db7189683f78ee36f8c1badb1c96490aa2 01cdd985832015db204fc28961cc96e69e81457fe8 yes very simple 4 bolts hold it down on frame 2 fuel lines on mine and the wire harness and 2 ground wires but very easy you will need help guiding the universal back on to the pump shaft i pulled min in about an hour and tazz you were right about the groves in the wear plates one of mine was really bad i worked it with sand paper and a sharpning stone fine and cores for about 3 hours to get the groves out and make it smooth i just got every thing back together have not tried it have just a couple more items to put back before testing
Let's hope it's going to run good as new now :)
I spent a few hours on one before, multiple sheets of sand paper. Even if it's not a mirror surface, as long as it's dead flat and clean, it should be good to go.
