1978 632 Bobcat No Travel, Bucket works fine
BRO0214
Hi
I'm new to the Forum and I am enjoying reading it. Lots of good information.
I recently purchased a Bobcat 632, the bucket works good, but there is no travel forward or Reverse.
It was traveling good, then it stopped on one side, then all together, it may of ran low on on oil as there was a leak on the tilt hose. It took half a pail to fill it.
The odd time it will seem like it is trying to move if I move both levels back all the way. But normally there is no sound when you move the levers.
One thing I noticed when I unloaded it off the trailer is, it rolled right off when I tilted the trailer, don't think this is normal
I have ordered a manual but have not got it yet.
I am going to get new filters this week, I will change the one in the block on top of the pump, and the spin on one mounted at the back.
Is there anything else I can Check?
Thanks in advance for your help.
Thanks RD
Hi I changed the filter in the block on top of the pump, The machine now moved about 200 ft before doing the same thing. I’m not sure which part is causing the filter to plug as I have not received my manual yet.
Any insight to this problem would be appreciated
