Got a little farter on the brakes, but ran into a few issues. First I had to source a 1/2-20 banjo bolt. None of the local big parts stores had one so I had to purchase online. Got it all put together and started by bench bleeding the master cylinder, then hooked up the brake lines and started to bleed them but notices that fluid was leaking out around one of the crush washers, so I tightened a little tighter, did that 2 more time to where I was afraid I might break the bolt. Took it apart and determined that the old banjo fitting had to large of an opening for the banjo bolt and crush washers to seal? Went back and ordered a new banjo fitting, should see it in a day or so. Also had to source a return spring for the brake pedal arm from ACE hardware too.
