1845C flow rate on aux foot pedal circuit
skidsteer.ca
register with www.mycasece.com
16 gpm at 2300 psi
1845C
Skid Steer​
ENGINE​
Model.................................. Case 4-390
Type............................................. Diesel
Cylinders............................................. 4
Bore/Stroke ...................... 4.0" x 4.72"​
(102 mm x 120 mm)
Displacement.............. 239 in​
3 (3.92 L)
Fuel injection ............................. Direct
Horsepower per SAE J1349 and J1995 –
Gross .......... 60 (45 kW) @ 2200 rpm
Net ............. 57 (43 kW) @ 2200 rpm
Peak torque –
@ 1300 rpm....... 179 lb·ft (243 N·m)​
POWERTRAIN​
Drive pump ..... Tandem, axial piston​
hydrostatic transmission
Flow ............................... Bi-directional
Controls........ Low-effort, servo assist
Drive motors...... Fixed displacement​
high torque /low speed
gerotor motors
Final drive........ Dual stage reduction​
chain drive to all wheels
Drive chain –
Size................................... No. 80 HT
Brakes ....... Mechanical parking latch​
spring applied, cable release
Engagement........... Raise the seat bar
Travel speed...................... 0 - 6.0 mph​
(0 - 9.7 km/h)
HYDRAULIC SYSTEM​
Standard equipment pump –​
Gear pump driven directly
off engine crankshaft
Pump flow @ rated engine rpm
Total ........ 16.0 gpm (60.6 L/min)
Loader control valve............... 2-spool​
mono cast with
float detent
Main relief ........................... 2300 psi​
(159 bar)
Hydraulic Filters ................. 6-micron,​
spin-on replaceable element
w/warning light​
AUXILIARY HYDRAULICS​
Loader arm mounted –
Standard ...... 16 gpm (60.6 L/min)​
@ 2300 psi
OPERATOR
ENVIRONMENT​
Roll out ROPS/FOPS canopy
w/side screens
Seat presence switch
Vinyl seat
2" (51 mm) retractable seat belt
Restraint bar w/integral armrests
Two hands-only control levers
Hand throttle
Loader control lockout system
Loader arm lock strut
Front and rear halogen floodlights
Floor cleanout panel​
INSTRUMENTATION​
Electro-mechanical hourmeter
Fuel level LED bar graph
Warning lights –
Alternator output
Battery voltage
Fuel level
Engine coolant temperature
Transmission charge pressure
Transmission temperature
Engine oil pressure
Air cleaner restriction
Hydraulic filter restriction
Systems normal
Warning alarms –
Alternator output
Engine oil pressure
Hydraulic oil temperature
Battery voltage
Seat belt reminder​
ELECTRICAL SYSTEM​
Alternator................................. 65 amp
Battery ......... 12 volt low-maintenance​
685 cold-cranking amps
SERVICE CAPACITIES​
Fuel tank.................... 21.5 gal (81.4 L)
Engine oil w/filter ......... 6.7 qt (6.3 L)
Engine cooling system......... 18 qt (17 L)
Hydraulic system –
Reservoir
w/filter change ....... 23 qt (21.8 L)
Total ............................. 42 qt (39.8 L)
Chain tanks (per side) ...... 5 qt (4.7 L)​
OPTIONS​
OPERATOR​
'S COMPARTMENT
Deluxe suspension seat
Seat backrest extension
Horn
3" (76 mm) seat belt
Foot-operated loader controls
Low noise package​
OTHER​
Backup alarm
Rotating beacon
High-flow auxiliary hydraulics
30 gpm (113.6 L/min)
Front and rear lift brackets
Cold start kit
Cooling package
Drawbar
Special paint​
BUCKETS​
Bucket Struck Heaped
Width Capacity Capacity Weight​
DIRT​
63" 9.1 ft​
3 11.8 ft3 374 lb
(1.60 m) (0.26 m​
3) (0.34 m3) (170 kg)
73" 10.6 ft​
3 13.9 ft3 410 lb
(1.85 m) (0.30 m​
3) (0.39 m3) (186 kg)
82" 14.5 ft​
3 19.0 ft3 593 lb
(2.08 m) (0.41 m​
3) (0.54 m3) (269 kg)
UTILITY​
63" 15.6 ft​
3 19.5 ft3 462 lb
(1.60 m) (0.44 m​
3) (0.55 m3) (209 kg)
73" 18.1 ft​
3 22.8 ft3 496 lb
(1.85 m) (0.51 m​
3) (0.64 m3) (225 kg)
LIGHT MATERIAL​
80" 25.4 ft​
3 32.2 ft3 588 lb
(2.03 m) (0.72 m​
3) (0.91 m3) (262 kg)
TIRES​
Pneumatic (tubeless)​
Goodyear 12.00 x 16.5, 6PR Traction
Width over tires................. 72" (1.83 m)
Galaxy "Beefy Baby"12.00 x 16.5, 10PR
Width over tires............. 72" (1.83 m)
Galaxy "King Kong" 12.00 x 16.5, 10PR
Galaxy "Fat Foot" 15.5 x 16.5, 12PR
Width over tires.............. 78.9" (2.01 m)​
Non-Pneumatic​
Mitco 8.00 x 16 Industrial Lug, Solid
Width over tires.............. 61.6" (1.57 m)
Airboss 8.25 x 15 GP/Industrial
Width over tires.............. 68.7" (1.75 m)
Airboss Altrakka II 12.00 x 16.5
Width over tires.............. 70.9" (1.80 m)​
Page 1 of 2​
DIMENSIONS​
A.​
Overall operating height – dirt bucket ................................ 145.5" (3.69 m)
Height to*​
B.​
Bucket hinge pin................................................................ 116.75" (2.97 m)
C.​
Top of rollover protective structure (ROPS).................... 80.25" (2.04 m)
D.​
Bottom of level bucket, loader arm fully raised ........... 111.25" (2.83 m)
Overall length –​
E​
. w/o attachment .................................................................. 101.25" (2.57 m)
F.​
w/bucket on ground........................................................... 132.4" (3.36 m)
G.​
Dump angle at maximum height –
Dirt bucket ................................................................................................ 41°​
H.​
Dump height – loader arm fully raised –
Dirt bucket.............................................................................. 89.5" (2.27 m)​
J.​
Reach – loader arm fully raised –
Dirt bucket .............................................................................. 23" (584 mm)
Maximum attachment rollback –​
K.​
Bucket on ground..................................................................................... 30°
L.​
Bucket at full height................................................................................. 62°
M.​
Wheelbase................................................................................... 40.5" (1.03 m)
N.​
Ground clearance......................................................................... 8" (203 mm)
O.​
Angle of departure....................................................................................... 25°
Clearance circle front –​
P.​
Less bucket ................................................................................ 48" (1.22 m)
Q.​
w/63" (1.60 m) dirt bucket on ground .................................. 78" (1.98 m)
Q.​
w/73" (1.85 m) dirt bucket on ground .................................. 80" (2.03 m)
R.​
Clearance circle rear.................................................................. 53.8" (1.37 m)
Operating weight................................................................ 6,185 lb (2806 kg)​
NOTE: *Dimensions taken with full fuel, 175 lb (80 kg) operator, 63" (1.6 m) dirt bucket and
7.5 x 16, 6PR tires.​
PERFORMANCE SPECS​
Operating load ....... 1,750 lb (794 kg)
Tipping load.......... 3,545 lb (1608 kg)
Breakout force –
Lift cylinder.... 3,450 lbf (15 346 N)
Bucket cylinder.... 4,690 lbf (20 861 N)
Cycle time –
Raise .............................. 4.3 seconds
Lower............................ 2.9 seconds
Dump............................ 2.0 seconds
Rollback ........................ 1.4 seconds​
NOTE: SAE rated lift capacities. Cycle time
measured with rated load in bucket.
100 lb (45 kg) counterweight standard
equipment.​
When you tell them what loader you have they make the specs available. Hold the control key to select more then one model.
fyrwoodguy
fyrwoodguy
16 gpm at 2300 psi
1845C
Skid Steer
ENGINE
(102 mm x 120 mm)
3 (3.92 L)
Peak torque –
POWERTRAIN
gerotor motors
Drive chain –
(0 - 9.7 km/h)
HYDRAULIC SYSTEM
mono cast with
float detent
(159 bar)
w/warning light
@ 2300 psi
OPERATOR
ENVIRONMENT
w/side screens
Vinyl seat
Hand throttle
INSTRUMENTATION
Warning lights –
Alternator output
Battery voltage
Fuel level
Engine oil pressure
Systems normal
Warning alarms –
Alternator output
Engine oil pressure
Battery voltage
Seat belt reminder
ELECTRICAL SYSTEM
SERVICE CAPACITIES
Hydraulic system –
Reservoir
OPTIONS
OPERATOR
'S COMPARTMENT
Horn
Low noise package
OTHER
Backup alarm
Rotating beacon
Cold start kit
Cooling package
Drawbar
Special paint
BUCKETS
DIRT
63" 9.1 ft
3 11.8 ft3 374 lb
(1.60 m) (0.26 m
73" 10.6 ft
3 13.9 ft3 410 lb
(1.85 m) (0.30 m
82" 14.5 ft
3 19.0 ft3 593 lb
(2.08 m) (0.41 m
UTILITY
63" 15.6 ft
3 19.5 ft3 462 lb
(1.60 m) (0.44 m
73" 18.1 ft
3 22.8 ft3 496 lb
(1.85 m) (0.51 m
LIGHT MATERIAL
80" 25.4 ft
3 32.2 ft3 588 lb
(2.03 m) (0.72 m
TIRES
Non-Pneumatic
Page 1 of 2
DIMENSIONS
A.
Height to*
B.
C.
D.
Overall length –
E
F.
G.
H.
J.
K.
L.
M.
N.
O.
P.
Q.
Q.
R.
PERFORMANCE SPECS
Breakout force –
Cycle time –
equipment.
thanks for the reply ken ! now i can get going on researching if there's a possibility of a snowblower to fit my case and what the cost is. Anyone got any ownership reports on snowblower performance on their machine???? or recomdations of favorite brand of snowblower??? i'm getting tired of plowing my wood yard,and the lost space and high snowbanks! http://i116.photobucket.com/albums/o8/WILLIAMFGREENE/CHECKPHOTOS020.jpg
skidsteer.ca
Fyr
To post images, open the image in photobook, copy it (not a link to it) and then paste it in the typing window here. To make links work, put a extra space on each end of the link. They will turn blue in the typing window when they are working.
For some reason the (IMG) on each end of the photobook links do not work here. I just removed them and made sure the link had a space on each end to fix it.
If you send me a email I'd be happy to quote you on the Erskine blowers we sell.
Visit www.skidsteer.ca and check the sales page for more info. One of our ES 2000 blower would be a good match with your case.
