05 Ls185.b Right side drive slower to react
georgestjohn
The right side drive input is slower than the left side. I have standard hand/foot controls. I have tried adjusting the linkage as well as the neutral position to no avail. At full speed she wants to pull to the right. If I pull or push the hand controls at the same time the left side engages first. Any thoughts? Thanks, George
First start with the simplest adjustments.
Disconnect the rod that goes between the hydro pump lever and the lever of your hand control on both sides.
Check that the rollers by each handle are fully seated in the bottom of the plate with the notch. There is a bolt that connects both levers. If they are not both in the bottom of the notch than loosen that bolt and the rollers should move into the bottom. Tighten the connecting bolt.
Now adjust the rod that you previously removed so the bolt will fit into the hole of the lever with out moveing the lever. Tighten the bolt.
Drive the unit. If one side is faster than the other you can adjust this by loosening the four bolts, on the fast side, at the bottom of your hand levers, they hold the rubber boot also. Move the plate and boot back slightly and tighten one bolt. Drive it again. Repeat as necassary until the unit drives straight then tighten all bolts.
As for one side starting to pull before the other, you will need to be able to bypass the brake solenoid valve. If you feel confident that you can do that I will try to walk you through it.
The mounting bolt on the right side pump lever was slightly loose. I disconnected both rods, adjusted the slip plate until skid remained at a standstill. Then adjusted rods to correct length and reattached rods to pump lever and she works better than she has for quite some time. Thanks for the help Mike10. George
