Dbrider456
- Joined
- Aug 21, 2015
- Messages
- 2
Hey guys, so my machine sprung a leak at the hydraulic control valve, ends up a bolt on the end of the lift spool valve broke and caused the leak, the valve ended up needing to be replaced which I did on my own. Everything worked perfectly for about 20 hours. Then all of a sudden while moving a log Pile it would want to lift nearly as much as usual. The machine can still be used but I can only load the bucket half way with dirt, any more and the arms won't go past a certain point. When I bought the new valve it came with a bics that wasn't the same as the old so I swapped with new o rings. Is that something that could cause my issue? All lights on, no codes, machine works as it should just doesn't have the capacity, and I have not tried a pressure test yet. Any help would greatly be appreciated. Thanks
