Bobcat 773 turbo binding on r/s
tfg111
I have a 2001 bobcat 773 turbo skid steer that seems to bind on the r/s when going forward, I have rebuilt the entire r/s drive system with new bearings seals and chains but it is still doing the same thing. It seems to jump and jerk on the r/s when you start moving forward. anybody have this issue? any thoughts would be appreciated. Thanks
Do you have slack in the chains on the RH side? Or do you have manual drive and the neutral plate hardware is worn out.
Low hours 1500 I've tried adjusting the linkage on top of the pump and didn't notice any wear but I'll have to pull it apart and inspect it. Like I said Chains are new.
How did you try to adjust the linkage? There is only one way, if you do it wrong the machine will either creep or maybe even not drive at all. I do not think that you stroked the swash plate completely otherwise you would have issues starting the machine
Played with it in ever position possible it does not creep and is in a completely neutral position. It feels like it gets intermittent pressure on the r/s almost like it's jumping in and out of gear. Is there a proportioning valve or anything similar in the system? Just guessing at this point.
r/s what do you mean with that?
The drive is pretty simple, the hydrostatic pump sends hydraulic oil pressure to the drive motor, depending on your swash plate position. The drive motors are connected to the sprockets, which are connected via chains to the axle sprockets. If you replaced everything, like you said, in the chain case, it is possible that one chain has to much slack. That will cause the chain to bind up when it goes over the axle sprockets, which would explain your jumping and the pressure rise, because it is working against that.
Could you take a picture of the open chain case, preferrable the middle and front cover?
Did you check the bushings from the neutral plate and the blocks? If there are worn, you can not stroke the swash plate correctly.
What would be the correct procedure for stroking the swash plate? It's in complete neutral position now but maybe I'm doing something wrong. R/s while sitting in the machine or passenger side like in a car
Oh ok you mean RH side.
When you stroke the swashplate forward, you drive forward and same with backwards.
The easiest way is to put the machine on jack stands and then i can give you instructions how to test if you are in complete neutral.
Could you also take a picture of your Neutral plate, because by these older machines there a several setups even within one serial number break.
Here's what it looks like
Just some grease I applied in case it was sticking. Drove it today and the rh wheel actually stops for a second when moving forward and that's why it bucks and jumps I can't imagine it's just an adjustment.
And you hear no "Clunk" noise or so when this happens? Can you just go in circuits and just stroke one side and see what happens?
No clunk but the rh lever does feel hard to push at that point doesn't do it backing up or going in circles just when moving forward at slow speed when moving both levers forward once traveling at full speed it goes away
Could you take a picture from the neutral plate again, but from the other side?
If I push the rh stick forward as gentle and slowly as possible as soon as the machine starts to move it instantly lurches forward almost like it has a sticky valve or something there is not a Smoot transition from neutral to forward motion.
Ok, sorry that picture did not show what I was hoping for.
Are you able to record a video, without the machine running and then with the machine running?
Just record the linkage when you move it forward and backwards.
