- Joined
- Jun 30, 2009
- Messages
- 69
Last month I started the unit in the snow just to warm it up and make sure the battery was still charged. I walked back into the shop and about 10 minutes later I went out to check the temp and shut it down. I heard a steady beep and looked at the display but wasn't exactly sure what it was showing. Now we have some warmer days and I wanted to run it again to see if the code popped and if so what it was. I turned the key and was giving it the 5 -10 second glow plug warm up and as soon as it was in ready to start I got a steady beep and the code A0 6.
I can not find this code listed anywhere. I'm wondering if it is maybe the alternator? Air filter is AF but I checked it anyway. I'll attach a picture of the code.
Machine is the 508613### series
*UPDATE*
Videoed the screen. Once started, once not. The FUEL issue is due to faulty sending unit and that is not the issue. Not sure if anyone has seen this issue before. Maybe Mr. Tazza has?
Spoke to Bobcat shop, they had no idea and said I probably had lights out on the display. The lights appear to be working and the code seems to count down bouncing all over and ending on 6.
Bobcat said they can come here or I can take the unit to them and they can hook into the system to see what the code is. I would like to avoid spending a couple hundred bucks to learn what is going on here.
Found out it would be closer to $1,000.00+ for them to come check the codes...
ANY help will be greatly appreciated.
*UPDATE*
