- May 24, 2006
- 2,748
I was using my 453 this morning and when I turned the key off the gauges turned off but the engine stayed running. Had to go back to the engine and move the fuel shutoff solenoid by hand to shut it down. Got my test light out and found no power to the solenoid so I figured the timer had gone bad. Took the timer loose from the back of the relay mounting bracket and when I went to unplug it one of the wires just came out of the plug. It had broken off the terminal inside the plug.
Replaced the terminal and all is well again. I Just thought I'd post this in case someone has the same problem and needs an idea of where to look.
