Dec 11, 2023 #1 K kayreg New member Joined Sep 4, 2023 Messages 2 Bobcat 700 right side slow to no drive motion in forward works fine in reverse..pump or motor?
Dec 11, 2023 #2 L laurencen Well-known member Joined Oct 3, 2016 Messages 229 my first thought is the valve, the pump does not reverse changing direction, motor does but if you have the same flow and reverse not seeing how the speed could be different unless the valve is not fully opening
Dec 11, 2023 #3 brdgbldr Well-known member Joined Jun 1, 2012 Messages 1,214 kayreg said: Bobcat 700 right side slow to no drive motion in forward works fine in reverse..pump or motor? Click to expand... Make sure all your linkages from the lever to the control valve are still ok. Could have slipped.
