Bobcat 742 bogs down traveling forward.
brdgbldr
Try checking your governor. There is a process for adjusting it. It is also one of those neglected maintenance items. Make sure it has oil and the proper weight oil.
LazyKG
Assuming you have not swapped in an electronic ignition setup, check the point gap. My 732 w ford I4 will start to bog down going up even the slightest grade until I reset the gap.
