The Bobcat was sitting flat in the driveway. I opened the front plug for the first and put 9 gallons in it until it just started to run out. As I was pouring it in it started leaking out as shown in the pictures. I going to check the level tomorrow and lift the cab to see if there is a leak under there.From the picture showing the back of the chain case, it looks like the oil is coming from higher up.
You filled the chain case, did you fill it to the bottom of the threads on the front plug? essentially half full. I wonder if you over filled it and it's leaking from the inspection covers.
