Daveb68
- Joined
- Oct 17, 2018
- Messages
- 32
Can anyone send me over the wiring diagram or know we're i can download or purchase the wiring schematics for a Bobcat S-250's main wiring harness located
underneath the operators seat when the cab is lifted up.
I Will attach some photos & a video of the plug in the harness that I am trying to figure out we're the wires from that plug go to and what there purposes are so I can properly put them back together. It's mainly the red wire with the white stripe which I believe is for the brake solenoids hold side because the brake solenoid will intermittently lock up on me & that was one of the options it gave me in the code that I got stating that it could be a break in the wiring harness or a bad ground which there is obviously a break in one of the wires but I just want to be sure I know what and were those wires are supposed to go to before I go blindly connecting them to the wrong place and doing more damage than I already have on my hands now.
There is also a solid red wire that is off to the side with the blue scotch lock connector on it that has two wires connected to it. One of the two wires in the scotch lock is going back to the positive connection in the battery & the other red wire originally came off of the same plug we're the red wire with the white stripe is located but it broke off due to corrosion and it used to go into one of the vacant pins located right next to we're the red & white striped wire is but I'm not sure which vacant pin it goes to and is why I'm looking for the wiring diagram for that plug preferably or the entire harness.
The serial number for my Bobcat is: 321313656
Thank you in advance to anyone who can help me out. I'm desperate having already blown way to much money on the original repairs that obviously wasn't done the right way and the guy who did the work won't even tell me where each wire goes, probably because he doesn't know himself.
