Whining and creeping 763
teamt
Hey folks! New to the forum and now dealing with a poorly maintained bobcat 763 for light work on mother's horse stables. Dad took it on trade and didn't know much about its history. I am guessing mid-90's or earlier.
I rebuilt the front bucket cylinder last summer after it failed on him in the field. On to the next issue... the steering controls are loud and whining. I believe this symptom is not new. The unit creeps forward about a foot per minute when idling. If I am not careful and bump them, it will surge forward and kill the engine. The steering handles seem pretty sloppy. It sounds almost like a dry power steering pump although it seems to work reasonably well.
I've read through similar issues here but wonder if there a general rebuild you all recommend or a trouble shooting guide I should follow as a relative novice in hydraulic systems?
Hey guys I'm new here and I make Tutorial videos on YouTube for our bobcats mostly 743b and similar variants. Here are a couple examples of videos that I've done.
How To Set Bobcat Creep in LESS Than 8 MINUTES
Bobcat Steering Bushings Replacement: A Step-by-Step Guide
How to rebuild Bobcat drive motor for less then $100
Just a couple examples hopefully someone finds some use for them and hopefully it helps someone out! I look forward to being on here more often and helping out in any way I can. Hope y'all have a good evening and rest of your week
-Mike
Perhaps if you want to rebuild your drive motors or do the bushings it's straight forward and the motors should be pretty close to these let me know if you have any questions
Best of luck
Best of luck
Thanks! just what I needed.
