T Ted D New member Joined Aug 5, 2022 Messages 2 Aug 5, 2022 #1 hooked up grappler and aux hoses . took pin out of lever handle , but it won't move up or down
F Firefighter Well-known member Joined Dec 31, 1969 Messages 303 Aug 8, 2022 #2 possible stuck cable, If not used for a quite some time or aux solenoid not releasing u can remove solenoid at valve to check and see if its unlocking
OP OP T Ted D New member Joined Aug 5, 2022 Messages 2 Aug 9, 2022 #3 wow! it was stuck cable. thanks A little oil at each end of cable and a little pressure finally broke it loose. it sure felt like it was locked up. Thanks again
F Firefighter Well-known member Joined Dec 31, 1969 Messages 303 Aug 11, 2022 #4 excellent, it may need replaced
