No, that I can install new with used. Or No, that it will cause damage to the driveline.
Motor is between wheels with chain to each axle. If one wheel is larger one wheel will be faster than the other.hard on chains.No, that I can install new with used. Or No, that it will cause damage to the driveline.
You are meant to replace tyres one side at a time. When one is larger front or back on the same side, it does put more load on the chains. Over time, they will wear, the hope is that they are rotated enough to keep that wear as even as possible.Motor is between wheels with chain to each axle. If one wheel is larger one wheel will be faster than the other.hard on chains.
You'll tear the snot out of the sprockets and chains. Don't do it. BIG mistake. Keep same size tires on each side.You are meant to replace tyres one side at a time. When one is larger front or back on the same side, it does put more load on the chains. Over time, they will wear, the hope is that they are rotated enough to keep that wear as even as possible.
Working in dirt, it doesn't seem to be an issue, but asphalt or concrete is stickier and puts extra load on the drive train.
