TL230 Series 2 2012
Jenstibs
Hi, I have a Takeuchi 230LT Series 2 track machine with only 1000 hours. The machine was accidentally over filled with oil and had to have the head gasket replace. When we received it back it had a overheating issue. The head gasket needing replacing again and the head machine. When we got the machine back it has lack on power in low or high. Test perform Check timing fuel pump, valve clearance, return line, bypass furl line, changes electrical fuel pump, injected pump tested, boost pressure 11PSI, compression test, hyd filter ok, pilot pressure ok, drive motor relief pressure, flow test - drive pumps. No engine or exhaust smoke Takechui did not import these machines into Australia so knowledge or assistance is poor. We have spent $$ and still machine is not working. I would really appreciated some help advice or direction. Jenny ([email protected])
Before replacing the head gasket, did they check that the rods did not bend if oil was drawn in, damaging the gasket?
Nothing else really comes to mind to be the cause of lower power, after the head was re-done.
