TL12r2 throwing codes 523548 & 523591
187motorsports
Hello all
Got a brain stretcher for yall. My tl12r2 only throws the codes when trying to hook up an attachment ( brush hog and auger). Here's what it does. I'll hook up the brush hog. Turn it on turn hydraulics on turn 1way flow on and detent mode. The only thing that happens is when I push A detent, The hose jumps a bit. But if i turn it on 2 way, pressing B detent it spins up but just jumps when A pushed. Also while rasing the boom and pressing B. The hydraulics slow down. We've tested almost every switch and solenoid in the 1st aux circuit. Today we found that the ox controller has a red light solidly on when running. Keep in mind with just a the bucket hooked up the machine does fine. We got even as far as testing the canbus circuit and unplugging all controllers didn't change the 60ohm resistance. Only found 1 resistor that when unplugged showed 120ohm which I beyond is good but couldn't find the other to verify it when unplugged. Besides getting a scanner. Has anyone came across this problem or what else to test?
