Tire size preference
pls1911
What tire size do you prefer? 10.00 or 12.00? If OTT tracks are run does it make much difference? I'm looking at S590s and see both sizes.
I would think that 12's would be wider & the over-the-tire-tracks would also be wider & would help the loader to float across softer ground. If all else (expenses) are the same, I would suggest the wider. The only way I would use 10's, is if I was going into small openings, such as narrow gates, or if I was working in small areas often.
