Thoughts on 1989 743
shane12345
Just looked at a bobcat 743. Guy is asking $9500 canadian($7300USD). Made the 3 hour drive to check it out. There is are no other options for machines near me, in my price range. Everything works fine, little noisy when moving but I read it is common for them. Meter says 3400 hours, but doesnt work and guy said it is likely closer to 5500. Started right up when I turned the key.
Hydraulics are not leaking, no puddles or drip marks under it on concrete floor after using it. However underneath it is wet with oil when I rub my hand over it. No idea where it is coming from.
Thoughts about if I should pick it up or run.
See if the seller will lift open the cab for you so you can check the pump and motors for leaks. Most older machines leak, it's just that some leaks are easier to fix than others.
If you need it, buy it. Just about any hydrostatic drive machine that works better than a shovel will bring $7K these days, and if your "price range" is like my own, you are not going to spend a lot more than that.
My take is that you have now have to make another 6 hr rounder to bring it home! Most machines leak somewhat & being parked on concrete & no drips says a lot. All you have to do to is search prior auction sales to find the pricing & to me that price is cheap enough.
That machine looks great I have on that continues to impress me, they are easier to work on with out all the new computer chip BS, I'm in the school of old but good, unless i could afford new of course, but then I wouldn't be here listening to the Gurus
