Terex PT100 Forestry issues
Ljayc
My Terex PT 100 Forestry has 3 issues. 1. When I turn on key one click, computer comes on like normal. When I then turn key to start, it starts, and computer goes off until hydraulic reversing fan reverses. Takes 2-5 minutes. May be when it reaches a warmer temp. 2. When I'm traveling with the fast speed button pushed, the machine will come to a very quick stop and computer will go off but engine continues to run. Computer will then come back on in a couple of minutes. 3. I get an intermittent error code that says "Implement Valve Pilot Dump Fault" when first starting up. It goes away and everything seems to work. Any ideas on what to look for will be greatly appreciated. I'm in a rural area with service dealers many miles away.
Now the implement valve pilot dump fault doesn't go away and the bucket joystick will not work. Please give me ideas to fix this. Thanks in advance.
Did you ever solve this? I have the same alarm. All I have done so far is make sure all the fuses are good.
I have a 2016 ASV RT120. Now shows the implement dump pilot valve alarm. How did you fix it?
