T770 blowing fuse
conconinc
I have a 2015 T770 and it keeps blowing the fuse for the bobtach release and horn. It doesn't do it while it sits still and your using it but does it when you are moving only. I took it to the dealer and they changed the harness that runs under the engine which supposedly supplies the valve to open but that did not make a difference. They said it could be in the main frame harness and may have to change that. Well wiring harnesses are very expensive just wondering if anyone else has had this issue. Inspecting all the wiring it doesn't look like any have been damaged so don't really know where to begin and the dealer don't either don't want to pay him to replace parts that aren't necessary already cost $600.00 to get an I don't know answer.
We had problems with a power bobtatch and replaced the harness as you have done as well as the solenoid valves. I would look at the wiring going up to the horn button as that would be live power going to it and moving the controls something could be pinched or rubbed
