T650 problem with codes
MeanGene
T650 runs great for a couple hours, then the brake and hydraulics lock and it throws codes H3916 D7501 H3276 and H4016. Shut it off for a few minutes, start and codes go away and function returns. The longer you run it, the closer together the issues, so seems heat related. Any ideas?
The codes I could find all point to the joystick on the left side so start there look at wiring to the joystick also look at the wiring that goes through the joint of the joystick. It could be a bad joy stick as well
