T650 5 volt Sensor out of Range
elo0816
I have a 2105 T650 that at first I was getting a 5 volt sensor out of range error and the loader would spot working and now that code and the lap bar sensor out of range are flashing. I put a new lap bar sensor and still have the same to errors flashing.
With both the 5v sensor code and lap bar sensor code is a sign the Gateway controller has an internal failure. This is a common issue that ive seen many times. You will need to replace the gateway and have it programmed by your dealer.
Well turns out I made a rookie mistake. The new lap bar sensor comes with a protective magnet over the magnet area. I took it back apart and noticed it. I removed it put it back together and all codes are gone and it’s running fine now.
