does anyone have a manual on this machine.. found a switch with hole in it..i assume for the reverse alarm..still can't find info on the front rod solenoid short to ground error..There really is nothing about this anywhere, is there? Lots of places will tell what a 24-02 code is, but none will suggest what to do about it.
Chasing a few trails seems to indicate that it might be a rear remote solenoid issue, that might be a place to start.
There's nothing in the main manual thread for this, but I did manage to find one here in this site that everyone should have bookmarked as well.does anyone have a manual on this machine.. found a switch with hole in it..i assume for the reverse alarm..still can't find info on the front rod solenoid short to ground error..
Hey Dwarihay, On the left panel, there's a (I) button. Far right button. When you have error code happening,push that button. That code is GOLD!!!! The code you are describing, sound like an aux solenoid issue.does anyone have a manual on this machine.. found a switch with hole in it..i assume for the reverse alarm..still can't find info on the front rod solenoid short to ground error..
