dougholsted
- Joined
- Apr 14, 2017
- Messages
- 1
I have a new to me Bobcat T320. It has AC and it works well because I jumpered 12 V to the AC clutch and the AC works great. But I don't want to run it like that. The compressor clutch has a 6 inch pig tail with a connector on it. I can't seem to find any where on the wiring harness to plug into. There is a switch on the AC panel in the cab with a "*" on it. When that is on, I read 12V at the blue wire. I traced that blue wire down under the cab (with the cab up) and it is not connected to anything. It does read 12V there also. I tried jumping that wire to the AC clutch, but it does not pull enough amps to set the clutch. I think there must be a relay what is involved somewhere, but I just can't seem to locate it. Any thoughts or if someone can look and see how yours is plugged in, that would help. Thanks
