Sometime back I posted an issue with my bucket curl function not holding while running or parked. Hauling dirt debris it's not a big deal but running a brush hog it's a huge problem. Advice on here pointed towards leaking cylinder seals. Well I never got around to digging in but the issue is more involved. What I found was both the curl function and the lift arms also leak down. Must be some common valve in the circuit letting fluid thru. It seems to be getting worse. The T250 doesn't have a manual pressure relief anywhere does it? I've also noticed the quick attach cylinder moves with raising the bucket. It's not alot but clearly hydraulic pressure is making its way there as well when lift cylinder is activated. Sorry for long winded post but hoping something similar has been diagnosed in the past. Thanks in advance for any replies!
