setting hydraulic pressure on my 853
perry
The previous owner screwed with the pressure relief spool, I think?, it's on the main control body and has a nut and allen screw. I bought a 5000 psi gauge to set the correct pressure. Where do I connect the pressure gauge? and do I turn the allen screw in or out?. Thanks
Hook the pressure gauge to your aux hydraulic quick couplers. Wind the relief valve adjustment screw in for more pressure, out for less. All it does is changes the pressure on a spring and poppet.
Tazza, you da' man............... Thanks
