Scat Trak 2300 D
Ram Man
Hey guys, Got a Scat Trak 2300D- I think I have a problem with the left side drive motor. After it gets warm the left side looses power and you start to hear a buzzing sound like the pressure relief valve is bad.everything else works great. It only has 1200 hours on it. I checked the pump relief valve pressure and its to spec. 5000 psi @ 2500 rpm, I checked it cold, don't know if that will make a difference. If it is the motor, Volvo wants 7000.00 for the part. I's an Eaton/Charlyn VIS 45 series. Are these decent motors or are they prone to early failure?
sandhills-elect
I don't know much about these but i would switch sides and see if it follows or take to a hydraulic rebuild shop and have them look at it. I would think you could do alot better than that price. You might check here(https://www.surpluscenter.com/home.asp) Good luck Brent.
Take a look a this, i know it is for a 2000 but, way cheaper may contact them too.(http://cgi.ebay.com/NEW-Scat-Trak-1...=BI_Heavy_Equipment_Parts&hash=item5ad02b5f0e) Good luck Brent.
