scat trak 1300
powerking
looking for parts [used or parts machine] for 1300 mostly need engine mounts/drive coupling for motor-pump machine has a 1702 kubota for it will that have enough h.p.?? thanks i'm in mass.
The V1702 has about 32hp, its used to drive the Bobcat 743 series machines. I'm not sure how big your scat track is, but if its about the same or smaller, it should have more than enough power.
brochure for model 1300 shows 50hp?? it's a 2203? kubota. the 1702 is said to have 36hp when new would this cause pump damage from too little ,i know more than 50hp would hurt pump and might break something [caused from motor not stalling out ] i was told this by a mechanic when asking if a larger motor would work in my 1600 bobcat he said too llarge would overheat the pump when working the machine. thanks for opinions
This is what i was told too.
It will hopefully have the power, but its quite a difference between 36 and 50hp. Used V2203 engines are available on e-bay at a very reasonable price, if that was an option. The V2203 is about 44-46HP from memory, so its closer to the 50hp mark.
i have a manual electronically for the 1050 and 1350 . just send me your email address and ill send you a copy. the 1350 has the V1902B which is a 40 HP. the 1050 has the D1402B which has 32 HP.
I would like to have an electronic copy of the D1402 manual, my email is [email protected] Thanks!
Hey, I have a 1300C I think I'm throwing the towel in on. I was useing it and siezed the main hydraulic pump. Everything was in good working order (except the pump i guess) when it broke. I'm parting it out asap unless i can find a pump for cheap. Its on my trailer in CT. Give me a call if interested, Matt 860-883-3815
Can you send me the electronic service manual that you have? THanks a ton! my email is [email protected] THanks nate
