S185 lift cylinder bushings???
bkn74
I can find replacement pins and bushings for the tilt cylinders all day long. Can only find pins for lift cylinder. Anyone know a part# or source for lift cylinder bushings? Thank you
There aren't any bushings shown for any of the lift cylinders on the online Bobcat parts catalog, but they do show the tilt cylinder bushings. It's likely that there aren't any, which seems kind of short sighted as it is a wear point.
I work nights so I had plenty of time last night to search. Found several places that make bushings in the size i need. Went to local machine shop this morning to see worse case what I'd be out if pins won't cut it and i need bushings. Manager told me they would make bushings for 30 each and if cylinders weren't bad they would clean hole and make bushings fit for 30 each. So needless to say 60 a cylinder for having custom bushings made and installed isn't too bad. Now on to the rest of machine. Lol
