S130 Charging Problem solved
Tom in Mo.
Battery quit charging and the alternator was original so I threw a new OEM alternator in and that didn't fix it. So then started checking the wiring. Checked fuse and saw that the exciter circuit to the alternator was switched thru the Switched Power relay. Yep. The relay was working but the points inside not making contact.
Just letting every one know don't forget to check the relay in the fuse box.
