There are a few old threads on fabricating a REAR mounted tow hitch on a Bobcat. The idea is to tow an off-road trailer or other equipment. None of the threads gave specifics of a practical solution. so I wanted to offer my plans fr improvement by others with more knowledge and experience than I have. Gehl/Mustang/Yanmar have a central hole in the counterweight that is mounted under the engine door - so this is not a totally off the wall proposal. My T320 Bobcat hangs the counterweights off the sides at the rear from 3 holes. These 3 holes are to be the mounting points for the "drop" plates of the generic Service body hitch. I put drop plate in quotes because the plates will be horizontal, not vertical*as intended for truck use). An example of the hitch assy is Curt # 15903.or 15901 or Drawtite #41991. The plates will need to be extended from 16" to around 24" to clear the door. The square drawbar would be removable - so you can open the engine door. The drawbar would be cut down to length and secured with hitch pins. Seems simple/obvious - anyone done this or better? I have seen some Forestry cages for the rear but never any diy details.
