nobull1
- Joined
- Jan 4, 2007
- Messages
- 196
OK time for the next project on my 763. I had the main belt cover off the other day and seen some fresh oil down on the bottom of the cover. this doesn't surprise me because there is a lot of caked on crud all around, under, and behind the flywheel. The only thing that makes sense is the rear main seal leaking. So after looking at my book it appears that you can take a half dozen bolts out of the flywheel and pop it off. Then you take another few bolts out and take the bearing case cover off. I assume that the seal is in this cover and should be easy to replace? I will also assume that you don't have to take the shroud behind the flywheel off to get the bearing case cover off....that would not be good This seems like an easy job..ha..ha, but you know how things have a way of going, especially for me. Has anyone done this repair and offer any advise or tricks. The seal will be in in a couple of days so I just want to be prepared. Just don't say there isn't enough room and the motor has to come out.
