Re-Programming of Fuel Injectors 2014 S650
Skidmarx326
Location
Sheboygan Falls WI
I was running skid steer today, and at one point I got a E001613-04 telling me there is a fault on injector 2 & 3. Fine. Then I looked for new injectors, at a cost of $800/ piece. Before I drop $1,600 on new injectors I wanted to find out if it was worth time invested to pull injectors 2 and 3 and test them to verify before spending $1600. If I do pull these, will I still need programming if I re-use? Maybe this is obvious to somebody but diesel mechanics is not my specialty. Appreciate any input in advance.
I'd like to hear how this works out, i am unsure if the ECU can re-tune its self automatically when new injectors are installed, or if you need to do a special procedure to make it do it.
The doosan CR engine will still start & run with new injectors, but it does not re-tune itself automatically.
But for proper running, it should to be reprogrammed shortly after the injectors are installed.
