Quick Attach
nickvigilante
I have a bobcat 863 and the quick attach is all messed up. There are several cracks and the attachment point where the pins connect to the loader arms. The curl cylinder eye is also egged out. There is a 753 for sale locally with a blown engine and pump for $1000. Are the quick attach and cylinders interchangeable?
I woudl say NO< the cylinders are not the same, due to different lift abilities on the machines, BUT really simple, if you want to know for sure, is look up part numbers on both, to the parts you are hoping are compatible, and see if numbers match up
