Hello ,new member here ,have some problems with skid steer ,parking brake light flashes,volts only show 5.5 when running,hydrolic light on checked presher at filterhousing 140 psi ,replaced senser,I ended up loosening switches by valve controls so i can use,auto intake heater contdown not counting down,but manual bypass works,all other gauges work ,also starter was staying engaged after running,replaced starter,starter relay,naled that down to a starter interlock relay that was hanging up ,other wise runs good and strong,also replaced battery found all plates dry,original battery ,could of posably messed up digital control panal? If any could help with advice,would be appreciated thank you God Bless,CDL Asphalt Paving
