skidsteer.ca
- Joined
- Jan 20, 2006
- Messages
- 3,853
You have to upload them to a "folder" in the "media- photo section"Something no one has mentioned is the quality of the metal and the temper procedures used in making the machines and pins , which personally I think is the problem ---------------as far as grease goes have you'll noticed that a lot of manufacturrs have gone to the theory that if the pin rides in dirt they don't put a grease fitting on that pin as they came to the conclusion that the grease actually attracts and holds the dirt and causes more wear than no grease at all , with that said I see no grease fitting pins with more hours and less wear than pins that are properly grease that are worn out , so I don't think grease is the problem , it's poor quality steel ---------------today I am doing the pins , bushings and bucket ears on a 322 dipperstick and cradle which are about as bad as I have ever seen -----how do you post pictures on this site , i would like to show and tell sometimes
Then using 2 browser windows you can open the photo in one and paste it in your message windown in the second, while adding any text you want with it. There is a really good post here somewhere about this,
Failing that email them to me and I'll put them up
[email protected]
