Pics of rear stabilizer mounts for 753 pls
soutthpaw
Hi, Just wondered if anyone has a pic of the mounts that bolt to the underside of the 753 to mount the old style rear stabilizers? I need to either build a set or buy a set from the dealer. They don't look to complicated if I had a decent image of where they mount and what they look like. Also does anyone which hyd line is supposed to be for up and down. They are currently capped off and I am wondering if the top fitting or bottom fitting is supposed to be for down (extend) connection. The machine I just bought was plumbed for rear stabilizers but the stabilizers themselves had been removed. Anyway I got a used set from the local bobcat dealer for $200 but they did not have the lower mounts. They had a couple other sets for older 8 and 7 series for sale too I think.
i have a 743 that came with rear stabilizers and i removed them ..if i remember the bottom mounts were welded on to the machine ..tomorrow i will try to remember to take the camera and take a pi for you.
On mine they were welded on too, they are like 2 blocks of 1” steel welded together. One large one at the base then a smaller one on the top. I have them at home too, if jmatt20 can't get a pic let me know and i'll take a picture.
great thanks guys
Is this what you are looking for? I found some stabilizers on EBay Item number: 180376473914
nope those are the newer style pin mount stabilizers what I need is the pics of the bracket on the under side of the skid steer for the older style stabilizers.
sorry one of my buddies took the 743 out of the yard to do some volunteer work on one of the local baseball fields for 4th of july games..pics next week when it comes back...
I'm trying to use photobucket to host my files now, so hopefully the links will hold.
Image030.jpg Stabilizer mount picture by tazza_
Its welded under the chassis behind the rear wheel. The top part mounts to the upper pin, they are longer and have a washer to prevent it sliding off.
great thanks, how wide is the top piece? 1" 1 1/4" etc also how long ? thanks
Please post full info when done, I need to take notes in this dept.
Ok, the sizes are:
6” long
Base is 1” thick and 3 3/4” wide
The top is 1 1/4” square
They simply welded the 2 pieces together, nothing special here!
If you need any more info, just yell :)
Ok, the sizes are:
6” long
Well got the stabilizers installed just used a 2 pieces of 1 1/4 x4x5 steel plate and welded it right to the underside of the frame... worked well and easily removable... now I just need a good deal on a 709 backhoe. machine already has the backhoe mounts installed
