nuts hold the cab in place on 843
donald73d
There are two vertical studs that go up into the front of the cab. One takes the nuts off to tilt the tab back. They are both missing. Does anyone know the size and grade? Without them in place the cab would not stay put in case of a roll over so they they need to be replaced. I am thinking 1/2" grade 5.
1/2”-13 Grade 5 will work just fine. There's suppose to be a 1/4” x 1 1/2” x 2” plate with a centered hole under each nut also.
OK, thanks, I picked up a 3/4" today and its too big. So my guess was either 1/2" or 5/8". You confirmed 1/2".
