No traction on right side, seems to skip when pushing right handle forward.
Stevie D
Can anybody help me, we have a 763 G series Bobcat and i see fluid coming out of the rear right side axle, probably the bearings are gone up. Again we have a 763 G series and when we push the right handle forward it seems it doesn't want to move at all and then it might catch for just a second then nothing. What could this be. When the left handle is moved forward we have no problem turning right. It's just the right handle seems to be not catching gear or the hydralics pump must be failing. Can anybody help. I would really appreciate this kindly. Also if I could get a phone number to talk to someone that would be great as well. Usaully when turning right we would pull bacl left handle and push right handle forward, but when we are in low idle we can't go left when moving right handle forward.
You'll need to remove the front chaincase cover and have look at the chains and sprockets. The bad bearing could have caused the chain/chains to jump off the sprocket. After you find the problem someone here can help you thru the repair process.
