NH lx665 no start, no power to starter?
redbarnrick
I ran my lx665 all day, turned it off and when I restarted it ran 10 seconds, and died, it cranked easily but would not fire, I switched it to the service position it started and ran 10 seconds and died, now the EIC shows .0 on battery voltage and if I switch to service to get into the book the panel goes blank, I have replaced relays and interlock switch with spares both new, also the heater blower does not go on with the key in run or acc. Could the starter have gone bad, I checked and cleaned all connectors and checked fuses all are good. I'm stumped, Thanks in advance for any input!
I do not believe it is the starter maybe you should look at what ever controls your fuel to the engine. If possible wire the electric fuel shut off in the open position(if possible not familiar with that machine) and see if it will run. A 12 volt hot wire could be used to bypass a harness problem also.
Thanks
Could be as simple as a poor connection at the battery terminals. Pull the cables, clean the terminals on both the battery and cables, reconnect and check the battery voltage with a voltmeter. Should read at least 12.4 volts if fully charged.
I believe there's a fuse in the panel behind the cab that powers the EIC. 5 amp I believe.
